Voicemail goes not unread
Jan 22nd, 2008
We have Unity 4.2 running as Voicemail system integrated into an already deployed AD. Therer is one OU for voicemail only users name+DN.
So far this should be supported with Unity. Everything works fine, except that If I retrieve new messages, the messages go to unread after I hang up. Only if I delete the message the MWI goes away.
Has anyone seen this before?
Many thanks
Overall Rating: 5 (1 ratings)
Brandon Buffin Tue, 01/22/2008 - 07:38
  • Purple, 4500 points or more
This is configurable with the Advanced Settings Tool in the Unity Tools Depot. There is a setting called "Conversation - Mark messages read upon hang-up". Set this to 1 and messages will be marked as read when you hang up.
Hope this helps. If so, please rate the post.
Brandon
Brandon Buffin Tue, 01/22/2008 - 07:42
I just realized that starting with 4.2, this setting is configured on the subscriber or subscriber template. In Unity web admin, go to the Conversation section of a subscriber or subscriber template. There is a checkbox that says "Mark a message as saved upon hangup or disconnection". If you need to set this option for multiple existing subscribers, use the BulkEdit tool in the Unity Tools Depot.
Hope this helps.
Brandon
