Can't telnet to 7970G
Jan 22nd, 2008
We need to telnet to one of the phones to monitor some traffic but we can't telnet to it (, whenever we try we get the response:
Connecting To not open connection to the host, on port 23:
Connect failed
Has anyone come accross this before?
Paolo Bevilacqua Tue, 01/22/2008 - 07:21
I think these phones support ssh only. If you search the forum, there are post explaining how to do that, it's a bit complicated.
And after you do ssh into the phone, there is really much that you can do.
timgaunt82 Tue, 01/22/2008 - 07:27
Thanks, I've looked at the SSH but I wanted to look at the traffic logs to/from the phone. Can you suggeset any ways of doing this?
Paolo Bevilacqua Tue, 01/22/2008 - 15:09
These have to be accessed by the CCM or whatever controls the phone, details varies by the version you have.
webboy123 Mon, 03/10/2008 - 06:46
Try SSH not telnet as i am in on mine
also you may need the correct key to get in
webboy123 Sat, 03/22/2008 - 05:21
p.bevilacqua << Very good read
But i did not need to create the key as we just reflashed the phone and got in via ssh with the program
* still looking for a working config for sip provider
