WLAN Deployment
I am planning to migrate our wired network to wireless network with Cisco 1250 series AP and 4400 Series WLAN Controller. I have 50 Nos of VLAns in the current network. For authentication I am planning to use CSACS server. How can I provide redundancy in Wireless LAN controller and authentication ( ACS)
drolemc Mon, 01/28/2008 - 08:53
Wireless LAN Controllers can be configured for fail over. A fail over condition occurs when a primary controller goes down or fails for any reason. Then, a second controller takes over the operation. There is a good document which explains how to configure redundancy with WLCs. The document is available at
Scott Fella Thu, 02/14/2008 - 20:16
If you are looking for redundancy, make sure one WLC can support all of the ap's then get a second WLC. As for ACS, you can have 2 ACS and sync the database.
