E1 Module for 7206
Jan 22nd, 2008
hi,
i have Cisco 7206VXR (NPE-G2). I want to terminate E1 module on that router.
Can anyone tell me which E1 moudle is supported on this plateform. I am searching the E1 module on cisco website but not getting the right one.
Please guide me.
One E1 moudle is installed on my 3825
VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
will that moudule support in 7206.
I am waiting for reply
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Tue, 01/22/2008 - 08:59
7200 and 2800/3800 do not share any common hardware. How many E1 ports do you need? The smaller module (port adapter) for the 7200 is PA-MC-2E1. Then there are 8 ports modules.
wasiimcisco Tue, 01/22/2008 - 12:23
Thanks for the reply,
Can u please tell me is there any module that provide me Rj48 interface for E1. Because i am using 3825 with
that provide me RJ48. I wana have the same sort of module that provide 7206 with RJ48.
I am looking at cisco site but still not able to get it.
Paolo Bevilacqua Tue, 01/22/2008 - 13:45
Yes, all are RJ48 interfaces. If you browse in the technical information for "port adapters" you will see them.
Thanks for the rating and good luck!
