weight/metric and BGP default route from provider
tato386
Level 6
Level 6
I am getting two default routes from my two ISPs via BGP. Since the routes are now equal in weight/metric my outbound traffic is being balanced out both provider circuits. How can I add a weight or metric to one of the two so it becomes the preferred outbound connection?
Diego
Danilo Dy
Both ISP is connected to one router and you only received default route from both not full internet routing table?
Try this...
route-map DEFAULT-PREFERRED permit 5
match ip address prefix-list DEFAULT
set weight 150
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
! ...and put the route-map to your preferred ISP for outgoing traffic
neighbor a.b.c.d route-map DEFAULT-PREFERRED in
To make it work...
Router# clear ip bgp a.b.c.d soft in
Alternatively, you can block all incoming BGP advertisement from your upstream and just put a default route to both with higher AD to non-preferred ISP.
ip route 0.0.0.0 0.0.0.0 a.b.c.d 10 name preferred-isp
ip route 0.0.0.0 0.0.0.0 w.x.y.z. 20 name non-preferred-isp
Dandy
texanmutt
You can use local preferance for that.
Danilo Dy
Try this...
set weight 150
To make it work...
Dandy
Thank you sir. Your route-map option did the trick!
Diego
