WS-C3750G-TS-E (EMI)
Jan 22nd, 2008
hi, when i entred by hyperterminal to verify the SW image, i have find
C3750-IPBASE-M ! it's correct? because normaly i find IP Services Image. i want to confirm this if there is somebody who worked with with 3750-TS-E.
thank u.
ankbhasi Tue, 01/22/2008 - 06:00
Hi Mehiaoui,
AFAIK 3750-TS-E comes default with EMI image. Can you post the output of sh version or confirm if the model number is not WS-C3750G-24TS-S which comes with SMI image.
Ankur
msidahmed Tue, 01/22/2008 - 06:10
thank u,
when i typed sh version, i have this information :
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:19:56:D0:A1:80
Motherboard assembly number : 73-7058-13
Power supply part number : 341-0045-01
Motherboard serial number : CAT10385R53
Power supply serial number : PHI1023L1ZQ
Model revision number : M0
Motherboard revision number : C0
Model number : WS-C3750G-24TS-E
System serial number : CAT0948N4RW
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 28 WS-C3750G-24TS 12.2(25)SEE2 C3750-IPBASE-M
Sidahmed
msidahmed Tue, 01/22/2008 - 06:13
thank u,
Sidahmed
ankbhasi Tue, 01/22/2008 - 06:25
Hi Sid,
As of now this switch is running IP BASE image but can be upgraded to ADVANCED IP SERVICES also. Are you currently facing any issues with this switch or IOS?
Ankur
msidahmed Tue, 01/22/2008 - 06:31
yes, now i'm connect by hyperterminal to this switch
