sample config using IPSec VPN SPA using BGP WAN
Jan 22nd, 2008
where can i find a sample config which uses bgp as tranport between two locations and encryption is setup over bgp "cloud". Also static or OSPF routes from location a have to be transported between two -or more- locations.
fmasson Tue, 01/22/2008 - 09:00
thanks so far, i already used this document. Theres a CPE example which could match(?).
The components i use are more like "all-in-one" CE/PE functionality.
The problem is that i'll use RouteReflector and route-target import/export, so i've no "outside" interface oder vlan to bgp cloud.
