What Device on Which port
Answered Question
Jan 22nd, 2008
I want to map out my VOIP network.
I want to be able to tell what phone is on what port of my 3560. Is there a way to sort of ask the 3560 "what IP address is attached to you?"
Thanks.
Correct Answer by Edison Ortiz about 9 years 3 months ago
The phones are shown on CDP, type show cdp neighbor detail
Note.- I'm assuming you are using Cisco phones.
HTH,
__
Edison.
Overall Rating: 5 (3 ratings)
Correct Answer
Edison Ortiz Tue, 01/22/2008 - 06:33
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
massimiliano.se... Tue, 01/22/2008 - 06:33
  • Silver, 250 points or more
If the telephone is Cisco you can use the command:
"show cdp neighbor detail".
I hope this helps.
Best regards.
Massimiliano.
ankbhasi Tue, 01/22/2008 - 06:34
  • Cisco Employee,
Hi Friend,
You can issue "show cdp nei detail" and it will list you the neighbor details on that por with the ip address.
Also you can issue a command "sh mac-adress-table " and get the mac address of the ip phone learned on that port and then go to the layer 3 switch if 3560 is not working as layer 3 switch and issue a command "sh ip arp " and get the ip address for that mac address.
If your requirement is something else please come back with the same.
Ankur
*Pls rate all helpfull post
