Hi i have to write some code to parse dump.txt file and retrieve user information.
My first question is : what is the structure/ format of the attribute "Expiry :"
The second question would be, how can i find, if a user is disabled when the number of failed login attempts exceeds the limit.
In this case i have observed that the Status attribute does not change value, when user is disabled.
