sdsl 878 router line-rate changes on reboot
Answered Question
Jan 22nd, 2008
Having issues with the line-rate with SDSL router 878. Everytime i reboot the router the line-rate seems to change which casues it to loss internet connectivity. In order to restore internet connectivity you need to manually configure the line-rate. Has anyone had this problem or assist me with resolving this problem
Correct Answer by Paolo Bevilacqua about 8 years 12 months ago
Hi, according to:
http://cisco.com/en/US/prod/collateral/routers/ps221/prod_bulletin0900aecd801d5c4c.html
If you upgrade to 12.4(6)T, that would give you 3.05 firmware, chances are it will solve your problem.
Overall Rating: 5 (1 ratings)
vital-group Fri, 01/25/2008 - 02:25
Thank for the prompt response. The router does not recognise the sh dsl interface command. However, i have included the results for sh controllers dsl 0:
ital-Brentwood-Data#sh controllers dSL 0
DSL 0 controller UP
SLOT 0: Globespan xDSL controller chipset
Frame mode: Utopia
Configured Line rate: 2048Kbps
Line Mode: Two Wire
DSL mode: SHDSL Annex B
Line Re-activated 0 times after system bootup
LOSW Defect alarm: ACTIVE
CRC per second alarm: ACTIVE
Line termination: CPE
Current 15 min CRC: 0
Current 15 min LOSW Defect: 0
Current 15 min ES: 0
Current 15 min SES: 0
Current 15 min UAS: 341
Previous 15 min CRC: 0
Previous 15 min LOSW Defect: 0
Previous 15 min ES: 0
Previous 15 min SES: 0
Previous 15 min UAS: 0
Line-0 status
Chipset Version: 0
Firmware Version: R3.0.1
Modem Status: Data, Status 1
Last Fail Mode: Failed during Carrier Detect status:0x8
Line rate: 2056 Kbps
Framer Sync Status: In Sync
Rcv Clock Status: In the Range
Loop Attenuation: 13.0 dB
Transmit Power: 14.5 dB
Receiver Gain: 27.420 dB
SNR Sampling: 39.8690 dB
Dying Gasp: Present
Vital-Brentwood-Data#
Vital-Brentwood-Data#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(4)T8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 11-Aug-07 03:34 by khuie
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
Vital-Brentwood-Data uptime is 1 week, 17 hours, 53 minutes
System returned to ROM by reload
System image file is "flash:c870-advsecurityk9-mz.124-4.T8.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 878 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FCZ1148628S
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
