No isdn connection , %VIP-3-BADMALUCMD
Jan 22nd, 2008
our client his isdn connection didn't work well .Line is comming up for one second and then going down.We received this message : Jan 20 17:42:21 GMT+1: %VIP-3-BADMALUCMD: slot4: VIP2,
Unsupported MALU command 165, arg=0x4, pascb=0x614DED80.
ROUTER INFORMATION :
sh ver
Cisco IOS Software, RSP Software (RSP-JSV-M), Version 12.4(13.5),
INTERIM SOFTWARE
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 15-Feb-07 00:38 by prod_rel_team
ROM: System Bootstrap, Version 11.1(8)CA1, EARLY DEPLOYMENT
RELEASE SOFTWARE (fc1)
BOOTLDR: RSP Software (RSP-BOOT-M), Version 12.2(37), RELEASE
SOFTWARE (fc1)
BENOSrc01 uptime is 13 weeks, 22 hours, 32 minutes
System returned to ROM by reload at 22:02:41 GMT+1 Thu Apr 5 2007
System restarted at 14:48:17 GMT+1 Sun Oct 21 2007
System image file is "slot0:rsp-jsv-mz.124-13.5.bin"
Last reload reason: Unknown reason
Cisco RSP4 (R5000) processor with 262144K/2072K bytes of memory.
R5000 CPU at 200MHz, Implementation 35, Rev 2.1, 512KB L2 Cache
Last reset from power-on
Chassis Interface.
1 FSIP controller (4 Serial).
2 VIP6-80 RM7000B controllers (2 FastEthernet)(2 Serial)(1 POS).
2 VIP2 controllers (2 FastEthernet)(8 Serial)(2 E1)(2 HSSI).
4 FastEthernet interfaces
76 Serial interfaces
2 HSSI interfaces
1 Packet over SONET interface
123K bytes of NVRAM.
32768K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
125952K bytes of ATA PCMCIA card at slot 1 (Sector size 512
bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
Slave in slot 3 is running Cisco IOS Software, RSP Software
(RSP-DW-M), Version 12.4(13.5), INTERIM SOFTWARE
Slave: Loaded from system
Slave: Cisco RSP4 (R5000) processor with 262144K bytes of memory.
I know there are bugs in 12.1 but not in a higher release
regards
Dirk
Overall Rating: 3 (1 ratings)
Goutam Sanyal Tue, 02/12/2008 - 22:46
  • Silver, 250 points or more
Hi Drik,
You are right.
As per Cisco: %VIP-3-BADMALUCMD: Unsupported MALU command [dec], arg=[hex], pascb=[hex]
Explanation: The Route Processor (RP) or the Route Switch Processor (RSP) has forwarded an unsupported command that the Cisco IOS software does not recognize.
I'll glade if I help u further.
Goutam
Pls rate if it works
