Change Spanning tree diameter ?
Answered Question
Jan 22nd, 2008
Is there any way to change the Spanning tree diameter of 7 switches on a 3550 ?
This is purely for study purposes.
Cheers,
Phil.
Correct Answer by skarundi about 9 years 2 hours ago
Nope. the command reference says you can change the diameter from 2 - 7. the 3550 global command to change STP diameter starts with "spanning-tree vlan".
URL: http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_25_seb/configuration/guide/swstp.html
Overall Rating: 5 (1 ratings)
ankbhasi Tue, 01/22/2008 - 08:00
Hi Phil,
You can only change it between 2-7, neither less nor more can be configured.
Ankur
