CW Updates
Jan 22nd, 2008
All of sudden CW stoped sending me network information at the same time I have added new devices to the network and CW is not discovering it. I am new to CW so Im not that familiar with trouble shooting it. Is there a specific place I should start? Maybe there are specific things to look at.
I looked at some logs and found that were updated some software.
Campus Manager, CiscoWorks Common Services, CiscoView, Device Fault Manager, Internetwork Performance Monitor, Integration Utility, Resource Manager Essentials
Installing Device Package(s), invoked from GUI
15 Jan 2008,14:31:21 EST Install Device Package(s) Executed
It shows Jan 15 14:31 as the update time, and 3 min before that was the last time I received any email notification.
Joe Clarke Tue, 01/22/2008 - 11:40
Part of the Device Package installation process involves shutting down all CiscoWorks daemons. It can take about 30 minutes before everything comes back online again. But if CiscoWorks is still not working for you a week later, then something must have gone wrong when the processes were restarted. Please provide the output of pdshow as well as the version of LMS and the platform on which is is running.
d_ferraro Thu, 01/24/2008 - 08:41
Thank you for you reply, we did a simple restart of the CW server and all is well.
