Keystrokes in console output gibberish on 7200
Jan 22nd, 2008
I am having some problems with my serial connection to any 7200 series router. It seems that the console text shows up fine, but once I enter a keystroke, it sends gibberish to the screen. Example: When I press enter it will send either an "M" or an "-".... No idea what is wrong, I have tried using three or four different terminal programs and all of them produce the same results. I have also tried several different baud rates and re-installed my COM port drivers.
I find it interesting that this only occurs on 7200 routers... Everything works fine on all of our Cisco switches. Please let me know if anyone knows a cure for this.
Thanks.
plumbis000 Tue, 01/22/2008 - 08:23
What is your config register set to? This will allow you to determine your baud rate.
osirislink Tue, 01/22/2008 - 13:13
Confreg is set to 2102 and baud rate is 9600. Any ideas?
plumbis000 Tue, 01/22/2008 - 14:05
are you directly connected or are you using reverse telnet?
Are you able to telnet (or SSH) to the device without getting all the garbage output?
osirislink Wed, 01/23/2008 - 05:51
I am directly connected to the console port via serial connection. When I telnet to the device it works fine.
plumbis000 Wed, 01/23/2008 - 09:23
I/O controller or NPE-G1/G2? If it's an IO controller I'd assume it's probably messed up, as it has to be a console port problem if you can telnet without issue. This wouldn't surprise me as those IO controllers are giant pieces of crap. (I've worked with a lot of 7200s and 9 times out of 10 the IO controller is the thing that causes issues)
osirislink Wed, 01/23/2008 - 09:43
I'm fairly certain the problem is on my end somehow. My buddy can console in fine via his COM serial connection.
