ip routing protocol purge interface
Jan 22nd, 2008
When i enable IP ROUTING on a 4503 i see this in the running-config
ip routing protocol purge interface.
while if i enable IP ROUTING on a 3507 routing it shows IP ROUTING in the running config.
although ip routing gets enabled by the above mentioned command in 4503, but what exactly the difference is ??
