Locked out of 3560- Need Help???
Jan 22nd, 2008
Hi All,
We have configured a new 3560 with 'login local' for vty&con forgot to put the username. Did the 'write mem' and unable to login to the switch via console/vty. It is asking for username.
Please suggest the solution (password recovery procedure)..?
Thank you
MS
fortis123 Tue, 01/22/2008 - 10:12
Thank you.. but I think I have not framed my question properly... Is the password recovery is only the way to get in the switch or any other way..?
Thank you
MS
ankbhasi Tue, 01/22/2008 - 10:17
Hi Friend,
You already have the solution :)
Ankur
