Ringtone will not play
jmachiggins
I have installed a new ring tone on a 4.1.3 CallManager cluster. I modified the XML file and restarted the TFTP server. I can see the tone, but it will not play. Anyone run into this before?
Thanks.
Justin
5 Replies 5
egrinkin1
Hi Justin,
Did you create and upload a new Ringlist.xml?
I just worked on this today in CUCM 6.0. The new Ringlist.xml did not work because I named it RingList.xml. Once I renamed the file with the lower case "L" and uploaded it, the new ring tones were available.
Good luck and let me know if this helps!
This is a windows system so I just edited the existing file. Thanks though.
Justin
Ah the good old days. Good old days + Windows OS?
I'm sure you did this already, but you moved the raw files into the same folder right?
Yeah. I moved it there. Everything looks right it just won't play.
Sorry I can't help J.
Good luck!
