Cat 6000 or 6500
Jan 22nd, 2008
  • Bronze, 100 points or more
This should seem like a trivial matter, but I am simply trying to figure out if I am working on a Cat 6000 or 6500. I am doing work remotely so I can't just go and take a look at the switch.
The people on site claim that this is a 6500, but what I have seen seems to indicate that it is a C6000. Here is a show version from the switch in question:
PROD1#sh ver
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(13)E6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 18-Apr-03 11:44 by hqluong
Image text-base: 0x40008C00, data-base: 0x41C3A000
ROM: System Bootstrap, Version 12.1(11r)E1, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-JK2SV-M), Version 12.1(13)E6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
PROD1 uptime is 50 weeks, 4 days, 16 hours, 7 minutes
Time since PROD1 switched to active is 50 weeks, 4 days, 16 hours, 9 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 21:02:57 PST Fri Dec 15 2006
System image file is "sup-bootflash:c6sup22-jk2sv-mz.121-13.E6.bin"
cisco Catalyst 6000 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID SAL0721DXF3
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
41 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
72 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K).
PROD1#sh mod
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-S2U-MSFC2 SAL0721DWEJ
2 16 SFM-capable 16 port 1000mb GBIC WS-X6516-GBIC SAL0720D9WH
3 16 SFM-capable 16 port 1000mb GBIC WS-X6516-GBIC SAD06100259
4 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL0726FR44
5 48 48-port 10/100 mb RJ45 WS-X6148-RJ-45 SAL0719CXEL
6 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD03265077
8 48 48-port 10/100 mb RJ45 WS-X6148-RJ45V SAL06261ME1
9 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL0719CU68
Mod MAC addresses Hw Fw Sw Status
1 0006.d65c.f5a0 to 0006.d65c.f5a1 4.2 6.1(3) 7.5(0.6)HUB1 Ok
2 000c.ceb5.3fd8 to 000c.ceb5.3fe7 5.3 6.3(1) 7.5(0.6)HUB1 Ok
3 0001.63d6.c302 to 0001.63d6.c311 4.1 6.3(1) 7.5(0.6)HUB1 Ok
4 000d.299c.d6f0 to 000d.299c.d6ff 2.5 6.3(1) 7.5(0.6)HUB1 Ok
5 000c.ceb6.7a90 to 000c.ceb6.7abf 1.2 5.4(2) 7.5(0.6)HUB1 Ok
6 00d0.ba45.9e30 to 00d0.ba45.9e5f 1.1 4.2(0.24)VAI 7.5(0.6)HUB1 Ok
8 000a.4124.dd68 to 000a.4124.dd97 1.0 5.4(2) 7.5(0.6)HUB1 Ok
9 000c.ceb5.1b78 to 000c.ceb5.1b87 2.5 6.3(1) 7.5(0.6)HUB1 Ok
Mod Sub-Module Model Serial Hw Status
1 Policy Feature Card 2 WS-F6K-PFC2 SAL0722E6TA 3.3 Ok
1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAL0721DXF3 2.5 Ok
8 Inline Power Module WS-F6K-PWR 1.0 Ok
Thank you,
Jim
ankbhasi Tue, 01/22/2008 - 09:31
  • Cisco Employee,
Hi Jim,
Looks to be Cat6000 but to make sure can you issue a command "sh idprom backplane"
Ankur
jim_berlow Tue, 01/22/2008 - 13:44
Thanks, Ankur. When I run this command I get the following:
PROD1#sh idprom backplane
IDPROM for backplane #0
(FRU is 'Catalyst 6500 9-slot backplane')
OEM String = 'Cisco Systems'
Product Number = 'WS-C6509'
Serial Number = 'TSC0724003R'
Manufacturing Assembly Number = '73-3438-05'
Manufacturing Assembly Revision = 'A0'
Hardware Revision = 3.0
Current supplied (+) or consumed (-) = -A
If I am interpretting that output correctly, it looks to report as a 6509. Curious since if I look at the unit from a neighboring switch (PROD4) it reports as a 6000 in CDP neighbor:
PROD4#sh cdp neig
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID Local Intrfce Holdtme Capability Platform Port ID
PROD1
Gig 1/2 120 R S I Cat 6000 Gig 2/10
PROD1
Gig 1/1 120 R S I Cat 6000 Gig 2/9
So with the first command, we are sure this is a 6000?
Jim
ankbhasi Tue, 01/22/2008 - 23:28
  • Cisco Employee,
Hi Jim,
It may report as Cat6000 as a switch class but the chassis which you are having is for sure Cat6509.
Can you paste the output of "sh cdp nei int detail"
Ankur
*Pls rate all helpfull post
