NBAR doesn't see rtp
Jan 22nd, 2008
We started to use Router 7206, as border gateway.
I activated NBAR on external interface and saw a lot of statistics: ftp, http, etc, but statistics' of rtp is zero.
We use IP PBX Asterisk on our side and make a lot of external calls over Internet.
Please, see attachment. There are more information.
Thanks.
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 01/22/2008 - 14:41
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I believe this version of IOS comes with RTP PDLM version 3 (you can see this by running show ip nbar version). If this is the case, there is a bug in this version which may misclassify RTP traffic. You should either upgrade your IOS, or download the rtp PDLM version 4 module from http://tools.cisco.com/support/downloads/go/PlatformList.x?sftType=Protocol%20Description%20Language%20Module%20(PDLM)%20Software&mdfid=268437988&treeName=Routers&mdfLevel=Model&url=null&modelName=PDLM&isPlatform=N&treeMdfId=268437899 .
To install this module, run the following from config mode:
ip nbar pdlm PATH
For example:
ip nbar pdlm tftp://10.10.10.10/rtp-124.pdlm
FYI the first version of code for this platform which has the fixed PDLM integrated is 12.4(11)T.
oleksa_ica Tue, 01/22/2008 - 23:44
Thanks a lot.
Yes, it's true.
20 rtp Mv: 3
But I couldn't download from cisco.com site:
rtp-124.pdlm
There was answer:
"To download this software, you must do all of the following:
Register
Due to United States export compliance regulations, you must be registered on Cisco.com to download this software. If you do not have a Cisco.com username and password, please register now. Registration is free. If you have already registered, please log in to proceed.
This information will not be used for marketing or sales purposes of any kind. Failure to provide correct information may result in a denial of service, thank you for your cooperation.
Log In
Log in now
I click "Log in now", but it opens previously PDLM download page.
We bought this router one month ago.
Must we purchase a service agreement to a correct this functionality?
Joe Clarke Wed, 01/23/2008 - 00:40
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I can't speak the specifics of your contract, but a valid Cisco.com login with software download privileges is required to get this update or an upgrade to IOS. Fixes of this nature would require some sort of service contract whether it be part of the initial purchase (i.e. warranty) or an extended contract. You should contact your sales or account team or Cisco TAC to discuss your options.
