copying start to TFTP-3122 bytes, sh run 4487 bytes
Answered Question
Jan 22nd, 2008
Copying start to TFTP server shows 3122 bytes copied over, however a sh run provides an output of 4487 bytes. Is the discrepancy between the above memory volumes normal?
Correct Answer by Richard Burts about 9 years 6 months ago
Said
I have checked on a couple of routers and they copy the same length when copying start or copying running. It looks to me as if changes were made in running-config that are not saved to startup-config.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Tue, 01/22/2008 - 10:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Rick
saidfrh Tue, 01/22/2008 - 11:12
Thanks Rick. I "copied TFTP to start", then a "sh run" showed same discrepancy in memory volume. We are using a 2821 router with full firewall features. I wonder if some attributes of the firewall do not copy to TFTP.
Said
a.cruea1980 Wed, 01/23/2008 - 07:12
  • Bronze, 100 points or more
Do you happen to have remarks in your configuration?
Have you done a simple "wr" recently to make sure run and start are the exact copy?
saidfrh Wed, 01/23/2008 - 07:42
Yes, I have description of the circuit.
Thanks.
