WLC AP-Manager Interace
Answered Question
Jan 22nd, 2008
I was wondering why it is no longer possible to create a "backup ap-manager" interface in WLC version 4.2. In the older versions, this was possible. The AP-manager interface was linked to one Distribution System Port.
Is the ap-manager interface now linked to the logical LAG channel ?
Gr.
Remco
Correct Answer by ankbhasi about 8 years 12 months ago
Hi Remco,
I am not saying you are wrong but that is not possible. If LAG is enabled you cannot configure interfaces for any port in specific.
The only way it is possible is when you enable LAG and do not reload the controller, that time you may be allowed to configure different physical DS port but when you reload the controller it all maps to port 29.
Ankur
*Pls rate all helpfull post
Overall Rating: 3 (1 ratings)
ankbhasi Wed, 01/23/2008 - 06:25
Hi Remco,
You can still configure multiple ap-manager interfaces on controller in 4.2 code and map them to different physical interfaces on controller.
This is not possible in WiSM and 3750 integrated controller because they are connected to backplane with LAG configuration. Also multiple ap-manager interface is not possible on 2xxx platform.
Ankur
remco.gussen Wed, 01/23/2008 - 06:51
Hi Ankur
Can you tell me where you can find that configuration option ? In my opinion, it is nog there anymore. It is not displayed on the ap-manager interface options or by the new interface config options..
Gr.
Remco
ankbhasi Thu, 01/24/2008 - 07:36
Hi Remco,
What you havr to do is go to GUI page where you create interfaces. Create a new interface example "ap-manager2" and assign same subnet ip address what you have assigned to first original ap-manager.
Then while configuring port number assign port number 2 and also there is a check box where it wil be written as "ENABLE DYNAMIC AP MANAGEMENT" just check that box and you are done.
Also connect that physical port 2 to the switch and then you will also see that whenever your APs join controller they will load balance on different ap-manager interfaces.
Ankur
remco.gussen Thu, 01/24/2008 - 07:41
Ankur
I'm talking about WLC version 4.2..... Please check the attachment and see what is happening..
The AP-Manager is connected to the logical port (LAG)... There is no option to assign the ap-manager to a specific Distribution system port..
Gr.
Remco
ankbhasi Thu, 01/24/2008 - 08:11
Hi Remco,
Can you confirm if this is WiSM module which is inserted in Cat6500 or WLC in 3750? Becase the attachment shows LAG is enabled which is default in WISM and 3750 integreated conttoller and if this is individual 4404/4402 then LAG is enabled on controller. If LAG is enabled than it is binded to port 29 which is logical port and you cannot specify individual physical port.
Ankur
remco.gussen Fri, 01/25/2008 - 00:30
Hi Ankur
I've got three 4402 controllers. LAG is enabled indeed.
Version 4.0 and 4.1.701?? were different. There you could choose for a ap-manager and a backup manager and link them to a physical DSP port..
Gr.
Remco
Correct Answer
ankbhasi Fri, 01/25/2008 - 05:53
Hi Remco,
Ankur
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
