WebVPN - Users can't log in
Jan 22nd, 2008
I created a new group on my 3000 series concentrator called "WebVPNGroup".
Type is internal - I want to configure each user account locally.
I created a new user and associated him with the WebVPNGroup. I gave the user the same password as the group.
I enter the external IP to the concentrator and hit the WebVPN portal -- I enter the username and password, but get a login error. Here is what the log shows:
437 01/22/2008 13:22:13.450 SEV=4 AUTH/9 RPT=737
Authentication failed: Reason = Logon Failure
handle = 787, server = 10.150.12.213, user = tyler
Any idea what I'm doing wrong? I'm using almost all defaults.
ajagadee Mon, 01/28/2008 - 00:01
  • Cisco Employee,
Did you get this issue resolved. What is the IP Address 10.150.12.213.
Also, did you try moving the Internal authentication to the top of the list under authentication servers and do the testing.
Arul
** Please rate all helpful posts **
