vista clients cannot connect when mac filtering enabled
Jan 22nd, 2008
I have a couple of clients that have Vista that cannot connect to Aironet 1200 APs version 12.3(8)JA2. XP works fine. I have WEP 128bit enabled also. When I disable mac filtering, all clients can connect with no problems. Also, is 12.3(8)JA2 the latest system version? The Product/Model Number is AIR-AP1231G-A-K9
gmarogi Tue, 01/29/2008 - 06:40
  • Bronze, 100 points or more
What is the error message that is displayed when the client doesnt connect?.
jemorris73 Tue, 01/29/2008 - 07:33
It'll ask if I want to automatically get new IP settings. It actually connects to the AP with the encryption key. If I give it a static, everything works fine. If i set it to obtain a DHCP address and then renew, it doesn't receive one. If I disable mac filtering on the 1200 AP, it will renew the ip address.
Trending Topics - Security & Network
