Call Forwarding an agent to a non agent phone
Jan 22nd, 2008
I have IPCC Express Standard version 4.5
The receptionist is the only agent for a CSQ and I'd like to add the ability to forward all calls received in the queue to a 'non-agent' phone when the receptionist is away from her desk.
Currently, if she hits the 'cfwdall' key on the phone, the calls stay in the q until she gets back.
Any idea's gratefully received!
Dan
david.macias Tue, 01/22/2008 - 13:13
  • Blue, 1500 points or more
What about having a shared line appearance?
david
Rob Huffman Tue, 01/22/2008 - 14:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Dan,
You cannot Call Forward an Agent DN :) If you do, direct calls to the DN will Forward properly but ICD calls will revert back to the Queue (which is what you are seeing).
Your best bet would be to add the "back-up" people as Agents or have them physically move to the Reception Desk when she is away.
Sorry man!
Rob
Abdulbaseer Mohammed Tue, 01/22/2008 - 22:59
  • Silver, 250 points or more
you can try setting up a hunt list and when she call forward all it goes to the hunt list based on your queue rule for time you setup.
You can add any extension to that list or even add the receptionist Queue number to put call back in queue.
Down side the calls will go to hunt list if the she is there but busy taking calls or many calls in CSQ.
good luck baseer.
