01-22-2008 01:40 PM - edited 03-15-2019 08:21 AM
CM 4.2(3) connected to 3825 with MultiFLex T1 card connected to Avaya PBX. Originally, the router was an H.323 GW and the T1 was a DS0/CAS circuit. I was able to offnet calls fine. Then to set up for E911, we changed the T1 to a PRI. Avaya operator changed his end, I changed the router config. Sh voice port summary and sh controller indicates all is good. I went to the CM and the GW. Now, calls going to the GW get fast busy.
Config below as well as show commands. I trimmed the show run:
isdn switch-type primary-ni
voice-card 0
dspfarm
dsp services dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
interface GigabitEthernet0/0
description Link to 008
duplex auto
speed auto
media-type rj45
negotiation auto
h323-gateway voip interface
h323-gateway voip h323-id 3825-1
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr xxx.xxx.xxx.xxx
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
negotiation auto
interface Serial0/0/0:23
no ip address
isdn incoming-voice voice
no cdp enable
control-plane
voice-port 0/0/0:23
echo-cancel enable type hardware
!dial-peer voice 1 pots
description Dial Peer for Outbound 4 digit on post dialing
destination-pattern ....
forward-digits all
On the CM, the GW window shows the GW, known by its IP address, device protocol H.225, and registration unknown
01-22-2008 02:10 PM
On the router, do a SH ISDN status. If it has correct layer 1 operation, it should be in Multi Frame Established.
Next, enable 'debug isdn q921' and do a shut/no shut on the T1 controller. Capture these logs, then turn off these debugs.
Finally, enable 'debug isdn q931' and make a test call through the gateway and capture these logs. Post them here so we can go through them.
01-23-2008 04:15 AM
OK, looks like I have a Layer 2 issue. Sho ISDN status indicates that the state is alternating between TEI_Assigned/Awaiting_Establishment
Show ISDN Status below:
3825-1#sh isdn status
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 176
Total Allocated ISDN CCBs = 0
01-23-2008 04:24 AM
router needs to be ISDN network-side:
int Serial0/0/0:23
isdn protocol-emulate network
01-23-2008 07:49 AM
OK, last post from p.bevilacqua fixed my L1/L2 problem - I now have MultiFrame Established. I have run the debugs as requested by a previous poster. Debug isdn q921 is below. Debug q931 and then placing a call produced not debug output
3825-1#debug isdn q921
debug isdn q921 is ON.
*Jan 23 16:40:09.987: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:09.991: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48conc t ft t
*Jan 23 16:40:20.055: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:20.055: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48f t
*Jan 23 16:40:30.119: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=48
*Jan 23 16:40:30.119: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=48
3825-1(config-controller)#shut
*Jan 23 16:40:38.243: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to administratively down
*Jan 23 16:40:38.247: %ISDN-6-LAYER2DOWN: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to down
*Jan 23 16:40:40.243: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to down
3825-1(config-controller)#no shut
3825-1(config-controller)#exit
3825-1(config)#exit
3825-1#
*Jan 23 16:41:06.719: %SYS-5-CONFIG_I: Configured from console by girardj on console
*Jan 23 16:41:09.955: %CONTROLLER-5-UPDOWN: Controller T1 0/0/0, changed state to up
*Jan 23 16:41:09.955: ISDN Se0/0/0:23 Q921: L2_EstablishDataLink: sending SABME
*Jan 23 16:41:09.955: ISDN Se0/0/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jan 23 16:41:10.955: ISDN Se0/0/0:23 Q921: Net TX -> SABMEp sapi=0 tei=0
*Jan 23 16:41:10.959: ISDN Se0/0/0:23 Q921: Net RX <- UAf sapi=0 tei=0
*Jan 23 16:41:10.959: %ISDN-6-LAYER2UP: Layer 2 for Interface Se0/0/0:23, TEI 0 changed to up
*Jan 23 16:41:11.955: %LINK-3-UPDOWN: Interface Serial0/0/0:23, changed state to up
*Jan 23 16:41:21.067: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=0
*Jan 23 16:41:21.067: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=0
*Jan 23 16:41:31.131: ISDN Se0/0/0:23 Q921: Net RX <- RRp sapi=0 tei=0 nr=0
*Jan 23 16:41:31.131: ISDN Se0/0/0:23 Q921: Net TX -> RRf sapi=0 tei=0 nr=0
3825-1#no debug all
Port Statistics for unclassified packets is not turned on.
