STP forwarding and pruning problem
pokwan
Vlan 23 and 28 are trunked between Cisco 4500 and Cat 3750. On the Cisco 4500, these 2 vlans are available on the "Vlans in spanning tree forwarding state and not pruned" on sh int trunk. However, on the Cat 3750 these vlans does not appear on "Vlans in spanning tree forwarding state and not pruned" on sh int trunk (see below).
A sh vtp status shows that the vtp pruning mode is enabled. A device on vlan 28 are connected on the Cat 3750 but is not accessable. There are a few devides on vlan 23 on the Cat3730 which are accessable eventhough it wasn't in "Vlans in spanning tree forwarding state and not pruned".
Even with pruning mode enabled, with vlan 23 and 28 defined, these 2 vlans should be in "Vlans in spanning tree forwarding state and not pruned" .
Can someone explain why this is hapenning? Any help is much appreciated.
TIA.
PF
CISCO 4500#sh vlan
VLAN Name Status Ports
1 default active Gi2/2
23 vlan_webserver active Gi4/3
25 vlan_server_client active Gi1/1
28 vlan_mgmt active Gi4/18
CISCO 4500#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi2/1 desirable n-isl trunking 1
Port Vlans allowed on trunk
Gi2/1 1,23,25-28
Port Vlans allowed and active in management domain
Gi2/1 1,23,25-26,28
Port Vlans in spanning tree forwarding state and not pruned
Gi2/1 1,23,25-26,28
Catalyst 3750#sh vlan
23 vlan_webserver active Fa2/0/17, Fa2/0/18, Fa2/0/19, Fa2/0/21
25 vlan_server_client active Fa1/0/1
26 vlan_server active
28 vlan_mgmt active Fa1/0/28
Catalyst 3750#sh int trunk
Gi1/0/1 desirable n-isl trunking 1
Gi1/0/1 1,23,25-26,28
Gi1/0/1 1,25
16 Replies 16
Edison Ortiz
Try hardcoding the trunking mode and trunking type on both interfaces
switchport mode trunk
HTH,
__
Edison.
Edison,
The above commands were hard coded on the interfaces and the result is the same.
With vtp pruning active, a sh int gi1/0/1 pruning on the 3750 shows that the vlan 23 and 28 were pruned for lack of request by neighbour (please see below).
Do you know the reason for this?
TIA.
PF
Cat3750#sh int gi 1/0/1 pru
Port Vlans pruned for lack of request by neighbor
Gi1/0/1 23,26,28
Port Vlan traffic requested of neighbor
That's odd, try disabling VTP pruning and enabling VTP pruning again. What version of IOS are you running on those switches ?
Edison,
I have disable and enable vTP pruning a number of times before but the same results.
The version of IOS is Version 12.2(25)SEE2. Does the information on sh VTP status matters between the 2 switches (3750 and 4500)?
TIA.
PF
Let's see the show vtp status from both devices.
Also, you may want to upgrade the 3750 switch to SEE4.
Edison,
Below is the sh vtp status for the switches. Please note that I have vtp pruning disabled on the cat3750 switch so that vlan 28 works on the switch.
Thanks.
PF
Cat4500#sh vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs : 9
VTP Operating Mode : Transparent
VTP Domain Name :
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Enabled
MD5 digest : 0xBC 0xF4 0x28 0xE1 0xBD 0xE5 0xD7 0x93
Configuration last modified by 172.31.1.1 at 0-0-00 00:00:00
cat3750#sh vtp status
VTP Version : 2
Configuration Revision : 29
Number of existing VLANs : 10
VTP Operating Mode : Server
VTP Domain Name : bos
VTP Traps Generat
Well, yes - we have a problem.
Not sure how you had VTP Pruning enabled since transparent does not support VTP Pruning as it's not part of a VTP domain.
If you want pruning to work, you need to have a server/client model. I see the 3750 has more Vlans than the 4500, be careful when making these changes as the 3750 is going to wipe the 4500 Vlan information (it has a highest configuration revision).
Make the 4500 a client, make sure the VTP domain is the same and your VTP pruning should work as advertised.
HTH,
__
Edison.
Edison,
The 3750 was on tranparent mode before. I change it to server mode as I need to play with the vtp pruning.
Will pruning work if they are on the SAME domain but both on transparent mode?
We do not want any vlan changes to go across switches so in this case vtp pruning has to be disabled on the Cat 3750 switches. Correct?
TIA.
PF
VTP Pruning works when a VTP domain is being used in a switched environment. VTP Transparent essentially disables VTP. If you want to prune between switches, you need to manually prune the Vlans on the inter-switch links.
Change both back to transparent and repost that output along with show vlan output.
Edison,
Attached is the output requested.
Thanks.
PF
In addition to Edison's post, the best way to work it out is to assign a switch as VTP server and other as the VTP client. As mentioned above the 3750 has the highest configiration number, I would suggest to put both the switches to a default VTP config revision and then work it out. The steps to set the config revision to 0 are :
1. Change the domain name of the switch to some bogus name and put the desired domain name back.
2. change the VTP mode to transparent mode and put it back to the Server or client mode as desired.
Also, as a best practice shut the trunk ports for a while till the time you are doing the VTP configs and bring them back once you have done the VTP configs.
HTH,
-amit singh
Amit,
Thanks for the information. Will make a note of this.
Thanks.
PF
Could you do a show spanning-tree vlan n for VLANs 28 on each switch please? Does the 4500 have anything on VLAN 28 apart form the trunk? Also, which switch is the Spanning-Tree root for that VLAN? Are you running PVST+ or MST?
Kevin Dorrell
Luxembourg
Kevin,
We are running PVST. Here is the sh spanning-tree vlan 28.
Thanks.
PF
cat 4500#sh spanning-tree vlan 28
VLAN0028
Spanning tree enabled protocol ieee
Root ID Priority 28
Address 0011.20b7.6240
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 28 (priority 0 sys-id-ext 28)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Gi2/1 Desg FWD 4 128.65 P2p
Gi2/3 Desg FWD 4 128.67 P2p
Gi4/1 Desg FWD 4 128.193 P2p
Gi4/18 Desg FWD 4 128.210 P2p
cat 4500#
cat 3750#sh spAnning-tree vlan 28
VLAN0028
Root ID Priority 28
Cost 4
Port 1 (GigabitEthernet1/0/1)
Bridge ID Priority 32796 (priority 32768 sys-id-ext 28)
Address 000f.2490.8c00
Aging Time 300
Gi1/0/1 Root FWD 4 128.1 P2p
