ACE: one-to-many port loadbalancing
Answered Question
Jan 23rd, 2008
I need to have the ACE do a kind of port load balancing within each real server in the server farm. This amounts to one incoming port and many outgoing port. Currently I can only see how to set one outbound port, how can I set many. The Alteons can do it, surely the ACE can too?
Correct Answer by Gilles Dufour about 9 years 4 months ago
The only way would be to configure a real server inside the serverfarm for each port you one to use.
There is no range option.
You could use a script to create the config for you and then copy paste it into the ACE terminal window.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Wed, 01/23/2008 - 02:17
  • Cisco Employee,
Gilles.
danger_mousie Wed, 01/23/2008 - 02:37
I'm looking into that now, but is it not the case that you con't configure 2 rservers with the same IP?
danger_mousie Wed, 01/23/2008 - 02:44
This isn't possible:
ace-2/C1(config)# rserver host Test1
ace-2/C1(config-rserver-host)# ip address 10.1.1.1
ace-2/C1(config-rserver-host)# inservice
ace-2/C1(config-rserver-host)# rserver Test2
Error: Duplicate IP address or subnet
Is there something that can be done with PAT?
danger_mousie Wed, 01/23/2008 - 04:35
Sorry Gilles, I misunderstood.
Did you mean the following?
serverfarm Test
rserver Test1 1112
inservice
rserver Test1 1113
inservice
rserver Test1 1114
inservice
I think this will work...
