Is there a way to unify multiple Voice ISDN-BRI to single group?
Jan 23rd, 2008
I'm just wondering is there a way to unify multiple BRI interfaces in signle than to include it in the dial-peer for easier call routing.
Thanks in advance
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 01/23/2008 - 02:03
  • Hall of Fame,
    Founding Member
Absolutely, trunk-groups:
int bri x/y
trunk-group telco
dial-peer voice 100 pots
destination-pattern ...
trunkgroup telco
Then, under "trunk group telco" you can optionally configure translation-profiles, hunt schemes and other things. "show trunk group" will give you the status of all the circuits in there.
z.zdravkov Wed, 01/23/2008 - 04:03
Thank you very much. It is very helpful. I just found this commands but wasn't sure are they working.
Now I'm goint to try them.
Thank you.
