Change pilot no PSTN E1
Answered Question
Jan 23rd, 2008
I have 01 digital E1 ISDN PRI PSTN link connected to Cisco 2811 NM-HDV2-E1/T1 card. The pilot no of this link is 4291100. Provider allocated from 100 (4291100) to 199 (4291199) series. Currently it uses only the pilot no 4291100 for outgoing calls. i want to change the display no to calling party according to the call originated extension no. Please help me with the configuration. Router has CCME & IP phones registered with this router
Correct Answer by paolo bevilacqua about 9 years 4 months ago
Ok, so you that certain extensions do show the direct number, while all the others, do show the main number.
For this, only translation rule works.
int serial x/y:15
translation outgoing makedid
voice translation-profile makedid
translate calling 100
voice translation-rule 100
rule 1 /3301/ /4291101/
rule 2 /3302/ /4291102/
Now, you can group extensions in a pattern for example from 3301 to 3307 do show DID:
rule 1 /33\(0[1-7\)/ /42911\1/
Then verify what you are sending out with "debug isdn q931" and "term mon".
If you need more than 15 rules, even using patterns, write back and I can suggest a workaround.
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 01/23/2008 - 02:21
  • Hall of Fame,
    Founding Member
There are two methods: dialplan command under telephony service, or voice translation-rule.
The first is easier being a single command, try it first. If doesn't work, write back here.
In any case, to check which number you are sending out, check "debug isdn q931" with "term mon". Note, you may need to set a dialplan/type by default router uses unknown/unknown.
rasankalakmal Sun, 01/27/2008 - 09:42
i tried; but did't work. Is this feature call DOD (direct outword dialing)? what should i get activated from SP's end. Please help me with detailed steps for config.
requirement in brief:
Caller Ext ------ Display no for outside
3301 -------------- 4291101
3302 -------------- 4291102
let say 3310 dials outside no and 3310 ext is not in this list. then i want to display common pilot no (4291100) for outside.
Correct Answer
paolo bevilacqua Sun, 01/27/2008 - 14:58
  • Hall of Fame,
    Founding Member
int serial x/y:15
rasankalakmal Sun, 01/27/2008 - 19:37
i stucked in the "translation outgoing makedid". U mean here, this command under serial interface. But only the following commands available under "t". This is a NM-HDV2/E1T1 interface.
tarp
timeout
transmit-interface
trunk-group
tx-ring-limit
Pls help. Also tell me What service i have to get enabled from Service provider.
paolo bevilacqua Mon, 01/28/2008 - 03:08
  • Hall of Fame,
    Founding Member
My bad. Under voice-port x/y/z:15
translation-profile outgoing makedid
You shouldn't need anything from telco. When you send a valid calling number with DID, it shows to the called phone. Anything else is replaced with main number. This is the normal ways DID works.
