3745 - unable to boot as well not logging by console
Jan 23rd, 2008
we have restarted 3745 router , we are not able to access it through console as well not getting connected in LAN.We used control break also.Till hyperterminal screen is blank.
paolo bevilacqua Wed, 01/23/2008 - 02:33
  • Hall of Fame,
    Founding Member
Try opening it up, remove all interface cards, reseat all removable modules, check power cables. If no output to serial console (not even garbage), either the mainboard has failed, or the power supply has.
gajanangavli Wed, 01/23/2008 - 04:20
Router is power up , no output through the console even garbage.We insert 1FE 1R2W card and poweron router and this happen .
on another 3745 it shows
%ERR-1-GT64120 (PCI-1): Fatal error, Parity error on master read
GT=0x24000000, cause=0x00100000, mask=0x00D01D00, real_cause=0x00100000
bus_err_high=0x00000000, bus_err_low=0x00000000, addr_decode_err=0x00000470
r0 = 63714558 r1 = FFFFFFFF r2 = 0 r3 = 62F70000 r4 = 0
r5 = 0 r6 = 0 r7 = 1 r8 = 0 r9 = 8000000
r10 = 0 r11 = 63452229 r12 = 0 r13 = 6345222A r14 = 0
r15 = 8 r16 = 0 r17 = C100 r18 = 0 r19 = 3401C101
r20 = 0 r21 = 607458E0 r22 = FFFFFFFF r23 = FFFF00FF r24 = 0
r25 = 607458C0 r26 = 0 r27 = 4C2 r28 = 0 r29 = 40000000
r30 = 0 r31 = 0 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 63452244
r50 = 0 r51 = 4 r52 = 0 r53 = 3041A801 r54 = 0
r55 = 100000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 63452218
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 601DFC78
sreg = 3401C103 mdlo_hi = 0 mdlo = 9EF21AA
mdhi_hi = 0 mdhi = 4 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 601DFC70 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
how we can use that cards for the 3745.
paolo bevilacqua Wed, 01/23/2008 - 04:29
  • Hall of Fame,
    Founding Member
The error indicates either bad RAM, or faulty board.
Now I'm sure to understand the sequence. Without modules it doesn't produce any output, but with the NM insered, it produces the error above ?
