Cisco IAD 2431: SIP user agent
Answered Question
Jan 23rd, 2008
pls, any one can tell me how many SIP user agent can i put on IAD 2431 T1/E1?
exp Config for 1 sip user agent:
dial-peer voice 11111 pots
destination-pattern 11111
direct-inward-dial
port 1/0:15
forward-digits all
authentication username 11111 password xx
Cordially
Correct Answer by Paolo Bevilacqua about 9 years 2 months ago
Either use "service compress-config", or save/load config from server.
Overall Rating: 0 (3 ratings)
Paolo Bevilacqua Wed, 01/23/2008 - 03:09
  • Hall of Fame,
    Founding Member
What is your purpose ? If you want to authenticate callers that do sip to pots calls, apparently you can use a different username for each port.
If you want to register your router to some external sip server, you can have only one set of credentials.
y.talibi Wed, 01/23/2008 - 03:54
I have 150 sip user assotiated to dial_peer. each SIP user are registred to my SIP provider.
I want to know who many SIPuser/peer can'i use on IAD 2431.
see attached file
Paolo Bevilacqua Wed, 01/23/2008 - 03:59
  • Hall of Fame,
    Founding Member
I believe there is no hard limit.
y.talibi Wed, 01/23/2008 - 04:02
i think so, but the limit of the nvram can cause problem if the configuration file is big than nvram volume.
correct me pls.
Correct Answer
Paolo Bevilacqua Wed, 01/23/2008 - 04:05
  • Hall of Fame,
    Founding Member
