01-23-2008 02:55 AM - edited 03-05-2019 08:39 PM
Hi All
Please can you explain what this means? WHay is one supervisor warm and the other one active, what is meant by "warm"?
Catalyst 6000 supervisor 2 (Warm)
Catalyst 6000 supervisor 2 (Active)
Solved! Go to Solution.
01-23-2008 03:35 AM
If you are running in Native mode it depends on your redundancy mode ie.
RPR = cold
RPR+ = warm
SSO = hot
See attached link for more details
Jon
01-23-2008 03:35 AM
RPR = cold
RPR+ = warm
SSO = hot
Jon
01-23-2008 05:23 AM
Thank you.
