STP root bridge ?
Answered Question
Jan 23rd, 2008
In order to set a switch as the root bridge for STP I can use one of the following two methods:
spanning-tree vlan 'vlan-id' priority 4096
or
spanning-tree vlan 'vlan-id' root {primary}
Is there any other method to configure a switch (3550) as the root bridge ?
I was thinking along the lines of changing the MAC address if the two priorities are tied.
Cheers,
Phil.
Correct Answer by Jon Marshall about 9 years 4 months ago
Hi Phil
You cannot change the mac-addresses used for STP calculation on fixed chassis switches - see attached link for details
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801c9b4e.shtml#span_mac
So as the mac-addresses will always be different on different switches manipulating the priority either up or down on switches is the only way to affect the root bridge election.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 01/23/2008 - 03:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Phil
Jon
igor_kiselev Wed, 01/23/2008 - 07:41
Best way is to set STP priority to 0.
This puts switch unconditionally into STP root for VLAN so no other switch can ever beat it.
If you take a step further to make your LAN more deterministic then force another switch to become a secondary
Example: make Switch-1 to become ROOT Bridge for Vlan 100 and 101
Switch-1#
spanning-tree vlan 100,101 priority 0
Switch-2#
spanning-tree vlan 100,101 priority 4096
This makes you LAN solid.
