CUCM 6.X, CUPS 6.X and OCS, Sip proxy service not running
Jan 23rd, 2008
I have a customer who is trying to use his moc clients tied with his cipc phone. We have followed the Cisco document for OCS intergration (screen shot documentation) and used the LCS documentation for support. The fundamental problem at the moment is that the Cisco UP SIP Proxy service will not run in any case. This is causing the ctigw to fail. I have changed the service parameter on the cups for the sip proxy from the default to tesl.com and this has not resolved the issue. Any ideas on how to fix this before we continue with testing the integration. IPPM was currently working on this set up but this is failing now due to the sip proxy service not being able to run.
Feisal
feisalb Thu, 01/24/2008 - 03:42
Got the sip proxy service to run, it was bug id
CSCsi40623. Problem still exist with the MOC integration.
The customer can make an outbound call from MOC, which tells the Cisco phone what to dial, however when the other person answers the call, MOC still thinks it is calling. Also when someone phones ,the MOC does not ring.
Feisal
