CCME: Caller ID shows "911" on Unknown number calls from PSTN
System is 2821 with 1 VIC2-2FXO for PSTN access running CCME 4.2.
PSTN Caller ID works fine when it is sent from the CO, whether it is shown or restricted "Private Number". But in some cases, "911" shows up on the screen. A test phone shows "Unknown number" instead of "Private Number". What would be the cause and how can I debug this in the console?
Thanks.
paolo bevilacqua Wed, 01/23/2008 - 06:47
  • Hall of Fame,
    Founding Member
That would be "debug vpm signal" with "term mon".
But when you don't get a number, it means the caller-id reception has failed, and display it's picking some DP tag or destianion-pattern number that you have in config.
If you send the DP config, some workaround can be suggested.
