NM1 T3/E3 configuration
Answered Question
Jan 23rd, 2008
I like the url for a basic configuration for a new DS3 card in my router please.
Correct Answer by paolo bevilacqua about 9 years 3 months ago
Here you go:
http://cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/serial/pa-t3_serial_install_config/3504conf.html
Even if your router is not the onle listed, commands are the same.
Overall Rating: 5 (1 ratings)
zzbronski Wed, 01/23/2008 - 06:50
I checked this url and it is referencing a serial interface. The card I have is in a 3845 router. The card is a NM1-T3/E3 DS3 card that has a transmit and receive coax connections. The card is in the router and the green light is on solid for enable. When I look for the interface on the router it is not there. I assume this is because there is currently no cables connected to it. I would like to get a basic configuration for this as it is being connected to AT&T for our WAN interface.
zzbronski Wed, 01/23/2008 - 06:44
I noticed the url posted refers to a PA/T3. Is this the same as a NM1-T3/E3 DS3 card?
paolo bevilacqua Wed, 01/23/2008 - 08:29
  • Hall of Fame,
    Founding Member
Hi, please configure "card type T3 ", after that the interface will appear and you will be able to configure.
If still trouble, please post "show ver" and "show diag".
