Cisco 3845 and NM1-T3/E3 configuration
Jan 23rd, 2008
The card I have is in a 3845 router. The card is a NM1-T3/E3 DS3 card that has transmit and receive coax connections. The card is in the router and the green light is on solid for enable. When I look for the interface on the router it is not there. I assume this is because there is currently no cables connected to it. I would like to get a basic configuration for this as it is being connected to AT&T for our WAN interface.
Richard Burts Wed, 01/23/2008 - 10:05
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Kimble
I suspect that your problem has less to do with whether there is a cable attached and has more to do with the router not being sure what kind of interface to generate. I suggest that you configure this and see if the interface appears in the config:
card type t3 [slot#]
Since you mention AT&T I assume that it is T1 but if it were to be E1 then change the t3 to e3.
Rick
cfolkerts Wed, 01/23/2008 - 10:14
Don't forget the controller command. For example:
controller T3 1/0
zzbronski Wed, 01/23/2008 - 12:00
Yes, thats was it. Thanks for the assistance. This is the first time I have setup this type of interface in the router.
Richard Burts Wed, 01/23/2008 - 12:12
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Kimble
I am glad that our answers were able to help point you toward the solution to your issue. I assume that the rest of the configuration went ok?
Rick
zzbronski Wed, 01/23/2008 - 12:52
Yes, the rest of the configuration fell into place. THanks again for the assistance.
dfwest Tue, 06/18/2013 - 08:06
I have a 3845 currently with a T1 card installed and while relocating the router and it was down installed a NM-1/T3 card.  A "show diag" shows the card in slot 3 and the correct card type.  I am unable to perform either the card type or controller commands for this newly installed card.  "Card type ?" command only shows T1, E1, t1, e1 as options, not T3...  "Controller ?" command only shows T1, E1, t1, e1 as options, not T3...
Is only one active card allowed?
any suggestions?
Richard Burts Tue, 06/18/2013 - 09:32
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thank you for being specific that you have looked for the card type command and that there is not an option for your T3. My first guess at the problem would be the version of code that is running. According to Cisco documentation it requires at least  12.3(8)T to support that card. Can you tell us the specifics of the IOS image that you are running.
See this link for additional detail
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2.html
Rick
Richard Burts Tue, 06/18/2013 - 12:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thanks for the information about the version of code. Your version is certainly more recent than the code requirement. So there must be some other explanation. Would you post the output of show version and the output of show inventory?
Rick
Subeh Sharma Tue, 06/18/2013 - 21:25
For this card there will not be any t3/e3 controller rather a serial interface would get created. Check for serial3/0 or 0/3 depending on where the module is inserted. That would be your T3 interface on which you need to put IP address , service-policy etc.
Subeh
