How do I enable HSRP to work in event of BGP multi-homing peer failure
I am currently trying to lab a dual-homed internet scenario using HSRP object tracking that it will cut over in the event of a route learnt from the internet is no longer accessible.
We recently had a real life failure where standard HSRP was configured and it did not cut over because it was only tracking the status of the WAN interface rather than whether the BGP peering dropped. So interface was still up but no routes were being given to us via ISP. The result was that the HSRP did not cut over.
After some investigation it seemed that object tracking would solve this. But in the lab environment I cannot get this to work using just BGP. The message I get is
Track 1
IP route 4.4.4.4 255.255.255.255 reachability
Reachability is Down (unsupported)
9 changes, last change 00:01:08
First-hop interface is unknown
Tracked by:
HSRP Vlan20 0
It is reachable when I get this message. The only way I found round this was to implement a static route to the far end device but this still does not work because even when the route is gone it still believes it is alive and well because of the static route. So even this would not cut over. My belief is that HSRP object tracking is not working with BGP as a routing protocol. A lot of documents do not mention using BGP but do not explicitly say that it is not supported.
To summarize I need a mechanism to ensure that HSRP cuts over in the event of pure BGP peer failure. The current solution we have is textbook with prepending and I-BGP in place.
Does anybody have any ideas?
didyap Tue, 01/29/2008 - 11:09
  • Silver, 250 points or more
When you are running BGP with more than one service provider, you run the risk that your autonomous system (AS) will become a transit AS. This causes Internet traffic to pass through your AS and potentially consume all of the bandwidth and resources on the CPU of your router. Following links may help you
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
shahzad-ali Wed, 01/30/2008 - 07:54
We are using IBGP with HSRP and it works fine.
ISP1 ISP2
| EBGP | EBGP
IR1 --- IBGP Crossover --- IR2Active
Active ------ HSRP -------- Standby
SW1 ------- EC -------- SW2
firewall
Crossover to avoid single switch failover.
Use LP and AS-path prepend for your ISP2 if it backup.
HTH,
-SA
shahzad-ali Thu, 01/31/2008 - 08:26
Here is the config: It should work with the BGP route.
1. R1 -- EBGP 192.168.1.0/24 -- R2
2. R2 -- VRRP 10.1.1.0/24 -- R3
3. R1 is sending default via BGP
r1#sh run | beg router bgp
router bgp 1
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
neighbor 192.168.1.2 remote-as 2
default-information originate
no auto-summary
ip route 0.0.0.0 0.0.0.0 Null0
interface FastEthernet0/0
r2#sh run | beg track 1
track 1 ip route 0.0.0.0 0.0.0.0 reachability
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.1.2 255.255.255.0
duplex auto
speed auto
vrrp 1 ip 10.1.1.1
vrrp 1 timers advertise 3
vrrp 1 timers learn
vrrp 1 priority 120
vrrp 1 authentication cisco
vrrp 1 track 1 decrement 100
r3#sh run | beg FastEthernet0/1
ip address 10.1.1.3 255.255.255.0
duplex auto
speed auto
vrrp 1 ip 10.1.1.1
vrrp 1 timers learn
r1#conf t
Enter configuration commands, one per line. End with CNTL/Z.
r1(config)#router bgp 1
r1(config-router)#no network 0.0.0.0
r1(config-router)#
r2#sh vrrp
FastEthernet0/1 - Group 1
State is Master
Virtual IP address is 10.1.1.1
Virtual MAC address is 0000.5e00.0101
Advertisement interval is 3.000 sec
Preemption enabled
Priority is 120
Track object 1 state Up decrement 100
Authentication text "cisco"
Master Router is 10.1.1.2 (local), priority is 120
Master Advertisement interval is 3.000 sec
Master Down interval is 9.531 sec
r2#sh ip bgp
BGP table version is 2, local router ID is 192.168.1.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 192.168.1.1 0 0 1 i
r2#
r2#
*Sep 7 15:25:14.235: %VRRP-6-STATECHANGE: Fa0/1 Grp 1 state Master -> Backup
r2#
r2#sh vrrp
State is Backup
Preemption enabled
Priority is 20 (cfgd 120)
Track object 1 state Down decrement 100
Master Router is 10.1.1.3, priority is 100
Master Down interval is 9.531 sec (expires in 9.031 sec) Learning
r2#sh ip bgp
r2#
r3#sh vrrp
State is Backup
Preemption enabled
Priority is 100
Master Router is 10.1.1.2, priority is 120
Master Down interval is 9.609 sec (expires in 8.213 sec) Learning
r3#
*May 8 23:28:25.763: %VRRP-6-STATECHANGE: Fa0/1 Grp 1 state Backup -> Master
r3#sh vrrp
State is Master
Preemption enabled
Priority is 100
Master Router is 10.1.1.3 (local), priority is 100
r3#
HTH,
Regards, SA
shahzad-ali Thu, 01/31/2008 - 08:30
Please understand and plan before making changes into the production Env. Make changes during your maintenance windows with the rollback plan.
Hi Ali,
Don't worry I am nowhere near a production environment yet. I have tried your configuration in a lab and still cannot get the CE to recognise the fact that it is receiving a default via BGP. If you look at the attachment for All configs.txt on the Primary_Int you can see that it gets a default in via BGP but does recongise this as valid using VRRP.
I have added attachments of configs which essentially try and mimic what will be real environment where the customer has 2 CE devices connecting to completely separate ISPs and each ISP only gives them a default via E-BGP.
Details as follows
Primary_Int - Primary internet CE router
Backup_Int- Backup internet CE router
THUS - Primary ISP PE device
Verizon - Backup ISP PE device
shahzad-ali Thu, 01/31/2008 - 18:32
R1 in the scenario is the internet router or PE and consider R2 as a CE or your IR.
-Shahzad
Hi Ali,
I have some more information which may help. I am wondeering now whether you can implement VRRP alongside BGP:
Primary_Int#sho track
Track 1
IP route 0.0.0.0 0.0.0.0 reachability
1 change, last change 00:00:09
Tracked by:
VRRP Vlan20 1
