Force Answer
Jan 23rd, 2008
Does anyone know if IPCC express has the ability to force answer a call for an agent? When the call is pushed to the resource he hears a beep in his head set and the call is live.
This is in reference to the "Select Resource" step inside the script.
Abdulbaseer Mohammed Wed, 01/23/2008 - 15:00
  • Silver, 250 points or more
Look into auto answer. When you setup CSQ i think you can define it there.
good luck.
dvanzee@rgl.net Wed, 01/23/2008 - 15:42
Thanks for the suggestion, I only have the option for "Automatic Work" or "Wrap up time". Does anyone else have any thoughts?
l.demanet Sat, 02/09/2008 - 10:05
Did you think about enabling autoanswer on the line level, in CCM admin?
geoff@hp.com Sun, 02/10/2008 - 11:37
  • Red, 2250 points or more
Yes - enable auto-answer in CUCM on the contact centre line. That gives you the beep in the agent's headset.
Geoff
