2 SSID's in AP1121G
Is it possible to assign to different SSID's on an 1121AP? I would like to have both SSID's apply to the local subnet. However, one SSID would use one WEP key, while the secondary SSID would use a different WEP key. I've configured both SSID's in the AP interface. My question is this: On the Security->Encryption Manager tab, do I have to do anything special to assign the Encryption Key to a specific SSID? Or will both entered keys apply to both SSID's automatically?
didyap Tue, 01/29/2008 - 11:10
When there are two controllers, both of the controllers cannot be the primary. Only one controller can be the primary, and the other must be the secondary. As far as the AP that registers to the controller is concerned, it is recommended to set the switchport that the AP connects to as the access port, because the client VLAN is not related to the VLAN on which the AP sits. Following links may help you
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
