Does Campus manager 5.0.0 in LMS 3.0 supports ASA5520?
srego4 Wed, 01/23/2008 - 10:41
go to Common services > device update > and look for the asa5520 ... I believe they do have it. as I had to do the same for the asa 5505 and 5510.... There shd. be a package for asa 55xx....
you also need to have the latest mdf file (its all in the readme when you get teh device package).
Joe Clarke Wed, 01/23/2008 - 11:08
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, Campus does not support the PIX, ASA, or FWSM devices since they do not support CDP, and thus could not appear as connected on the map.
Joe Clarke Wed, 01/23/2008 - 21:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. What you are seeing is the best that Campus Manager will support an ASA device. For more in-depth ASA management, you should use ASDM or the Cisco Security Management Suite.
