01-23-2008 09:07 AM - edited 02-21-2020 03:29 PM
I have a VPN running between an ASA 5510 which is running version asa707-k8.bin and an 877 running version c870-advipservicesk9-mz.124-6.T8.bin. Users on the ASA LAN are losing connectivity to the remote end intermittently. I am getting the following error in the ASA log.
3|Jan 23 2008 13:59:43|713902: Group = 81.149.216.178, IP = 81.149.216.178, Removing peer from correlator table failed, no match!
3|Jan 23 2008 13:59:53|713902: Group = 81.149.216.178, IP = 81.149.216.178, QM FSM error (P2 struct &0x4458530, mess id 0x9f161880)
Donagh
01-29-2008 11:14 AM
Check the crypto map config properly and make sure if you have both L2L and Remote access vpn configured on same interface of ASA then the crypto map sequence number should be greater for Remote access vpn. Following link may help you
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
01-30-2008 01:45 AM
thanks for your reply. I already removed a redundant line from the VPN access-list on the 877 this caused the error in the log to disappear! still waiting to hear from the users.
