Requirements for WS-X4548-GB-RJ45
Answered Question
Jan 23rd, 2008
can you please tell me the hardware requirements for the WS-X4548-RJ45,
Everytime i plug in to 4006 i get
%SYS-3-P2_ERROR: 1/Unknown module (Field Replaceable Unit
WS-C4006 Software, Version NmpSW: 7.6(6)
Copyright (c) 1995-2004 by Cisco Systems, Inc.
NMP S/W compiled on Mar 17 2004, 20:27:33
GSP S/W compiled on Mar 17 2004, 17:21:15
System Bootstrap Version: 5.4(1)
Hardware Version: 3.2 Model: WS-C4006 Serial #: XXXXXXXXXXXX
Mod Port Model Serial # Versions
1 2 WS-X4013 JAE062601L9 Hw : 3.2
Gsp: 7.6(6.0)
Nmp: 7.6(6)
2 48 WS-X4148-RJ JAE0626040U Hw : 3.1
3 48 WS-X4148-RJ JAE06260242 Hw : 3.1
4 48 WS-X4148-RJ JAE062601A9 Hw : 3.1
5 48 WS-X4148-RJ JAE062604QQ Hw : 3.1
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65536K 40782K 24754K 16384K 9611K 6773K 480K 440K 40K
Correct Answer by ajagadee about 9 years 1 month ago
Is this is WS-X4548-GB-RJ45 or WS-X4548-GB-RJ45V. If WS-X4548-GB-RJ45 - you need a minimum version of 8.1(2) and if this is WS-X4548-GB-RJ45V, you need a minimum of 8.3(1)GLX. Please refer the below release notes for minimum version and details:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/release/note/OL_4502.html
Arul
** Please rate if it helps **
Overall Rating: 5 (1 ratings)
Correct Answer
ajagadee Wed, 01/23/2008 - 12:25
Arul
tpacjer Wed, 01/23/2008 - 12:46
what is the preferred route to get this card to work uprade the catos or convert and where can i find instructions to perform both.
