CUE customer Script Assistance
Jan 23rd, 2008
  • Bronze, 100 points or more
hi,
i need to configure the following and was hoping to get some ideas
Welcome to Company X, if you know your party's extension you can dial it at any time, for department A press 1 or 0 for assistance.
we have extension ranges from 1xx to 2xx.
Overall Rating: 2 (1 ratings)
singhcisco Sat, 03/01/2008 - 22:40
email me your call tree and I can send you the script. Let me know your cue version too.
a.gooding Sun, 03/02/2008 - 05:12
hey,
i got through a while back with this.
thanks
anwar-ahmed Tue, 07/08/2008 - 13:20
Can you help me.
I need main menu with prompt
Press 1 for Customer Support
Press 2 for Emergency Support
Press 0 or hold to Emergency Support
I do not know when I upload script I get error message. Thanks in advance
a.gooding Tue, 07/08/2008 - 16:22
can you upload your current script?
a.gooding Wed, 07/16/2008 - 05:40
hey
sorry for the late reply, too much things on the table these days :). did you get through with this?
if not tell us the version of the CUE you have presently. im not an expert by any means but have encountered my fair share of issues, most of the times my doing.
singhcisco Tue, 07/08/2008 - 18:18
what is the error message, can you make sure that the file name is not present or you can check the box while uploading the new script to over write if you are uploading the file with same name.
Why do you want to have option 2 and Zero for emergency support just one of them should be good.
anwar-ahmed Sat, 07/12/2008 - 09:05
Hi, I am getting some kind of internal error message. Enclosed please find the attachement.
Thanks in advance
anwar-ahmed Sat, 07/12/2008 - 09:07
Options are requirment but if it is not possible we can just use one option.
singhcisco Sat, 07/12/2008 - 12:12
thats fine you can have multiple options if thats requirement.
Have you tried to reload CUE and before you do that delete the call-in number 30000 for the AA.
After CUE reloads create the call in again.
and verify whether CLI that it exists and has the correct parameters.
anwar-ahmed Wed, 07/16/2008 - 07:20
Now it is working it was a problem with cue and script version.
a.gooding Wed, 07/16/2008 - 07:59
yeah figured as much hence the reason i asked for the version. had the same issue a while aback
at least now we know
Imthiyas Khan K I Mon, 07/21/2008 - 18:41
Hi Singhcisco,
Can you please help me to create the script.
CUE Ver : 3.1.1
My Call tree is :
Welcome Message
1 -> Sales
+ 1 -> Corporate Banking (DN : 1001)
+ 2 -> Local Banking (DN : 1002)
+ (3 or #) -> Main Menu
2 -> Fianace (DN : 1050)
3 -> About the Company(General info)
0 -> Operator (DN : 1010)
Thanks in Advance
Imthiyas Khan K I Tue, 07/22/2008 - 04:56
Thanks Buddy,
Just now only i get to know abt this tool..
Now my life is very easy.
