2821 with AIM-VPN/SSL-2 high CPU utilization
Jan 23rd, 2008
I have a 2821 that I am using in a IPSSEC VPN setup and the rotuer is experiencing very high CPU utilization when traffic rates are high (40 Mpbs).
I am concerned because I have another 2821 router using the on-board VPN module and its configuration is almost identical (another spoke on the DMVPN setup) to the 2821 with AIM module but the CPU utilization is drastically lower given similar traffic loads.
The 2821 with AIM module is running 12.4(9)T4. Is there possibly improvement in later code releases?
Anyone have any CPU utilization issues with there AIM modules?
Ralph
Ralph Rye Wed, 02/20/2008 - 20:16
I believe you are referring to this statement from the link you posted:
Restrictions for DES/3DES/AES VPN Encryption Module
•Rivest-Shamir-Adelman (RSA) manual keying is not supported.
Correct?
My question is do they mean Manual keying = pre-shared keys??
