Failover between WIC's
Jan 23rd, 2008
I would like to configure a 1720 12.1(27b) with failover between two WIC's. I've been searching for a document that might describe some scenarios but I haven't found any. Please point me in the right direction. Thanks
robert.horrigan Mon, 01/28/2008 - 13:08
Your routing protocol will take care of failover for WAN connections. You need to document your network and select the routing protocol that fits your design. If your WICS terminate at the same place, use either two static routes or enable a routing protocol.
