ASA 5520 v7.21 Assertion Failed (Block.c)
Jan 23rd, 2008
I am facing a quite interesting situation. I just upgraded my ASA 5520 from 7.0(5) to 7.2(1) with the same config file. The problem is that all of a sudden the ASA reboots and I receive this error message:
message #65 : assertion "0" failed: file "block.c", line 874
Memory usage goes to 100%, CPU keeps low (up to 5%). Any ideas on this?
Thank you.
ajagadee Thu, 01/24/2008 - 08:21
  • Cisco Employee,
This looks like a software bug to me. I have seen some similar issues with 7.2(1). Is it possible for you to upgrade to 7.2(3) and let me know if you still see the issue.
Arul
m.pinheiro Thu, 01/24/2008 - 10:13
Arul, thanks for your response. Interestingly I downgraded to version 7.0(5) and it is running normally. I have this same software version on another ASA and it is running normally. Anyhow I will try to upgrade to 7.2(3) as you recommended. I will let you know the results.
m.pinheiro Mon, 05/12/2008 - 15:35
Arul,
Sorry for taking so long to post here. I upgraded to version 8 and it now works perfectly fine.
Thanks once more.
Marcelo Pinheiro
