problem of "show bootvar" result
Jan 23rd, 2008
I have one Catalyst 6509 with 2 SUP1. When execute "show bootvar", the two supervisor engine have different parameter. Even I change "boot system" & "config-register" again, the boot parameter between two supervisor engine still different. Please also gove me some help to solve this problem.
Show Version :
IOS (tm) c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 07:56 by tinhuang
Image text-base: 0x40008C00, data-base: 0x417A8000
ROM: System Bootstrap, Version 12.1(4r)E, RELEASE SOFTWARE (fc1)
BOOTLDR: c6sup2_rp Software (c6sup2_rp-PSV-M), Version 12.1(13)E17, RELEASE SOFTWARE (fc1)
Core-01 uptime is 1 week, 1 day, 4 hours, 54 minutes
Time since Core-01 switched to active is 1 week, 1 day, 4 hours, 53 minutes
System returned to ROM by power-on (SP by power-on)
System restarted at 10:50:51 TWN Sun Jan 13 2008
System image file is "sup-bootflash:c6sup12-psv-mz.121-13.E17.bin"
cisco Catalyst 6000 (R7000) processor with 112640K/18432K bytes of memory.
Processor board ID SAL0551FG7W
R7000 CPU at 300Mhz, Implementation 39, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
1 FlexWAN controller (1 ATM).
16 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
22 Gigabit Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 112640K/18432K bytes of memory.
Configuration register is 0x0
Show Bootvar :
BOOT variable = sup-bootflash:c6sup12-psv-mz.121-13.E17.bin,1
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c6msfc2-boot-mz.121-11b.E.bin
Standby is up
Standby BOOT variable = bootflash:c6sup12-psv-mz.121-13.E17.bin,1
Standby CONFIG_FILE variable =
Standby BOOTLDR variable = bootflash:c6msfc2-boot-mz.121-11b.E.bin
Standby Configuration register is 0x2102
Show Redund states :
sh red states
my state = 13 -ACTIVE
peer state = 8 -STANDBY HOT
Mode = Duplex
Unit = Primary
Unit ID = 1
Redundancy Mode (Operational) = Route Processor Redundancy Plus
Redundancy Mode (Configured) = Route Processor Redundancy Plus
Split Mode = Disabled
Manual Swact = Enabled
Communications = Up
client count = 11
client_notification_TMR = 30000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0x0
Best Regards,
ankbhasi Wed, 01/23/2008 - 23:07
  • Cisco Employee,
Hi Jack,
There is no harm here and that is an expected behavior. If you are on RP (route processor) console the bootvar is referring to sup-bootflash.
If you do 'remote command switch show bootvar', it shows bootflash i.e. it is local to the supervisor.
Now, you do 'sh bootvar' on the RP what supposed show you settings for the active and standby supervisor. For the active - no
problem, we just read it on RP and get sup-bootflash. To get the same for the standby, we need ask standby *supervisor* for it. It returns bootflash that is local to the supervisor.
So, to summarize. The output you've sent doesn't show any problem and is an expected behavior.
Now coming to the config register settings it is fine on standby but on your active it is showing 0x0 which is the settings on RP of active sup. Just go ahead and change the config register as 0x2102 on the active RP and you will be good to go.
Ankur
*Pls rate all helpfull post
jackson.ku Wed, 01/23/2008 - 23:57
I tried to modified config-register and write mem, then executed show ver again, the config-register still 0x0 :
Core-01#config t
Enter configuration commands, one per line. End with CNTL/Z.
Core-01(config)#config-reg
Core-01(config)#config-register 0x2102
Core-01(config)#^Z
Core-01#
Core-01#
Core-01#
Core-01#
Core-01#wri mem
Warning: Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]y
Building configuration...
[OK]
Core-01#sh bootvar
Standby is up
Core-01#remote command switch show bootvar
Core-01-sp#
Configuration register is 0x10F (will be 0x2102 at next reload)
Core-01#
Maybe I must reboot this switch, break into ROMMON during RP booting, then modify confreg, not modify config-register 0x2102 in running-config?
The reason why I asked this question is I have FlexWAN & PA-A3-OC3 module installed at slot 3. Last week this switch reloaded. All configuration back exceptd ATM module configuration. The ATM module configuration still exist at "show start", but not exist at "show runn". I copy ATM module configuration from startup-config to running-config, It work again. I an afraid this problem related with different bootvar symptom. Can you please help to identify tese problem?
Best Regards,
ankbhasi Thu, 01/24/2008 - 06:33
  • Cisco Employee,
Hi Jack,
The problem you described does not seem to be related with boot variable settings. For config register part as you said to take in rommon and change the settings there should work and if you can arrange some change window then only go ahead with the step.
Ankur
jackson.ku Thu, 01/24/2008 - 06:45
Hi Ankur,
Many thanks. Do you have any suggestion how to troubleshoot the FlexWan & PA-A3-OC3 module failed to execute startup-config problem?
Best Regards,
ankbhasi Thu, 01/24/2008 - 06:53
  • Cisco Employee,
Hi Jack,
I am sorry but I do not have much experience on Flexwan card and PA-A3-OC3 card. May be some other experts can throw more light on the same.
Ankur
jackson.ku Thu, 01/24/2008 - 07:18
Hi Ankur,
Thanks a lot. I will start new conversation for my another problem.
Best Regards,
PS. I tried to rated your posts, but not succeeded. But rated to another people's posts succeeded .... >_< Why???
ankbhasi Thu, 01/24/2008 - 07:23
  • Cisco Employee,
Hey Jack,
That's OK. May be my bad luck :)
Ankur
