01-23-2008 09:36 PM - edited 03-11-2019 04:52 AM
I have an ASA5510 w/ v7.0(7). I'm trying to see why none of my machines can get on the network so I'm working the troubleshooting section and trying to ping the interface.
I entered:
hostname(config)# debug icmp trace
debug icmp trace enabled at level 1
I didn't do "logging monitor debug" because I'm accessing the 5510 through a serial port. And I couldn't do "logging buffer debug" like in the ASA70 troubleshooting docs, but I think the equal is "logging buffered debugging" which it accepted.
hostname(config)# logging on
Then I try to ping the interface (192.168.3.1) from a host on that interface and I get the error ...
192.16.3.22 icmp_seq_1 Destination Host Unreachable
Can anyone help, ideas, advice?
01-23-2008 10:02 PM
Did anything change in the firewall inside interface connection in relation to the vlan that connects into if any, where does the inside interface connects, check respective switchport and vlan menbership where inside connects etc.. did the firewall inside interface all of the sudden stopped responding to pings?
Can you ping the interface 192.168.3.1 from the firewall itslef when console? what is the interface status is it up/up down etc..
Rgds
Jorge
01-23-2008 10:18 PM
I was previously using a PIX 501, and replaced it w/ the 5510 so this firewall never responded to pings (or worked). Completely new config.
outside ----> ASA5510 (inside 192.168.3.1) ---> netgear switch (home version) ---> host machine (192.168.3.22)
So nothing changed other than a new firewall. This home version of the netgear switch doesn't have a VLAN config (which is beyond my know-how at the moment anyways).
And yes, I can ping all interfaces from the CLI console of the firewall with success, but can't ping the host. All interfaces (except for management) are up.
01-23-2008 11:05 PM
Still trying ... can't talk from any host connected to any ASA5510 interfaces, I thought I'd post a nat policy on one of the interfaces and my config.
If something here doesn't look right, please let me know, specifically the 'No matching global'.
hostname(config)# show nat
... (other interfaces)
NAT policies on Interface development:
match ip development DEV_NET 255.255.255.0 cluster any
static translation to DEV_NET
translate_hits = 0, untranslate_hits = 0
match ip development DEV_NET 255.255.255.0 dmz any
dynamic translation to pool 1 (No matching global)
match ip development DEV_NET 255.255.255.0 outside any
dynamic translation to pool 1 (199.199.xxx.14 [Interface PAT])
match ip development DEV_NET 255.255.255.0 development any
match ip development any dmz any
no translation group, implicit deny
policy_hits = 0
match ip development any cluster any
policy_hits = 0
match ip development any outside any
policy_hits = 0
And I've included my latest config as an attachment.
01-23-2008 11:12 PM
I take back what I noted, can you please repost the config, show run copy and post.
01-23-2008 11:27 PM
I'm configuring the 5510 through the serial console and trying to do the ping from within the 192.168.3.0 network and not from the management interface, Here it is ...
5510(config)# show run
: Saved
ASA Version 7.0(7)
hostname 5510
enable password <
interface Ethernet0/0
nameif outside
security-level 0
ip address 199.199.xxx.14 255.255.255.0
interface Ethernet0/1
nameif dmz
security-level 20
ip address 192.168.4.1 255.255.255.0
interface Ethernet0/2
nameif cluster
security-level 60
ip address 192.168.2.1 255.255.255.0
interface Ethernet0/3
nameif development
security-level 80
ip address 192.168.3.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
management-only
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
same-security-traffic permit inter-interface
object-group protocol TCP_UDP_ICMP
protocol-object tcp
protocol-object udp
protocol-object icmp
object-group network CLUSTER_GRP
network-object host 192.168.2.10
object-group network DEVELOPMENT_GRP
network-object host 192.168.3.10
object-group network DMZ_GRP
network-object host 192.168.4.10
object-group network INSIDE_GRP
group-object DMZ_GRP
group-object CLUSTER_GRP
group-object DEVELOPMENT_GRP
access-list INSIDE_ACCESS_OUTSIDE extended permit tcp any any eq ssh
access-list OUTSIDE_ACCESS_INSIDE extended permit tcp any any eq ssh
access-list ICMPACL extended permit icmp any any
access-list WEB extended permit tcp OUTSIDE_NET 255.255.255.0 host 192.168.4.10 eq www
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu dmz 1500
mtu cluster 1500
mtu outside 1500
mtu development 1500
no failover
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (dmz) 1 DMZ_NET 255.255.255.0
nat (cluster) 1 CLUSTER_NET 255.255.255.0
nat (development) 1 DEV_NET 255.255.255.0
static (management,development) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
static (management,cluster) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
static (management,dmz) 192.168.1.0 192.168.1.0 netmask 255.255.255.0
static (development,cluster) DEV_NET DEV_NET netmask 255.255.255.0
static (development,dmz) DEV_NET DEV_NET netmask 255.255.255.0
static (cluster,development) CLUSTER_NET CLUSTER_NET netmask 255.255.255.0
access-group INSIDE_ACCESS_OUTSIDE in interface dmz
access-group INSIDE_ACCESS_OUTSIDE in interface cluster
access-group OUTSIDE_ACCESS_INSIDE out interface outside
access-group INSIDE_ACCESS_OUTSIDE in interface development
route outside 0.0.0.0 0.0.0.0 199.199.xxx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:<
: end
01-24-2008 01:59 PM
I havent' been able to progress any further beyond this point (pinging the interfaces), but did receive the following from someone about ssh (which is what I'm trying to do). Is this correct?
"The ASA/PIX intercepts the SSH request. The only way I have gotten SSH to work through the pix is to do a port translation.
Static (inside,outside) tcp [external IP] 2222 [internal IP] 22 netmask 255.255.255.255
then allow 2222 to the external IP with the ACL."
