Help - Configure AP 1242AG
Jan 24th, 2008
Does anyone know how to configure the AP, so that the AP ip address and wireless user ip address in different subnet?
bcolvin Fri, 01/25/2008 - 14:20
you need to configure a VLAN for the AP (Native) and another VLAN for the SSID used by the client you also need to cofigure the switch port for dot1q trunking. it is reccomended you use the GUI/Web browser interface to do this as ther are many interrelated settings and the usint the Web interface takes care of them.
Good Luck
